複製帳務後立刻執行編輯有時會出現錯誤
複製帳務後立刻執行編輯有時會出現錯誤
文章richer » 2025年 10月 8日, 10:29
複製帳務 ( 按鍵盤 F8 ) 後,立刻執行編輯帳務 ( 按鍵盤 F3 ) 有時候會出現錯誤訊息。
錯誤訊息的內容如下
詳細資訊的內容如下
System.Data.OleDb.OleDbException (0x80040E4D): Not a valid password.
   於 System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection)
   於 System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject)
   於 System.Data.ProviderBase.DbConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection, DbConnectionOptions userOptions)
   於 System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup, DbConnectionOptions userOptions)
   於 System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection)
   於 System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
   於 System.Data.ProviderBase.DbConnectionClosed.TryOpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
   於 System.Data.ProviderBase.DbConnectionInternal.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
   於 System.Data.OleDb.OleDbConnection.Open()
   於 帳務小管家Emy.主畫面_帳務小管家.修改帳務記錄()
   於 帳務小管家Emy.主畫面_帳務小管家.c(Object A_0, KeyEventArgs A_1)
   於 System.Windows.Forms.Control.OnKeyDown(KeyEventArgs e)
   於 System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
   於 System.Windows.Forms.Form.ProcessKeyPreview(Message& m)
   於 System.Windows.Forms.TabControl.ProcessKeyPreview(Message& m)
   於 System.Windows.Forms.Control.ProcessKeyPreview(Message& m)
   於 System.Windows.Forms.Control.ProcessKeyMessage(Message& m)
   於 System.Windows.Forms.Control.WmKeyChar(Message& m)
   於 System.Windows.Forms.DataGridView.WndProc(Message& m)
    組件版本: 4.0.0.0
    Win32 版本: 4.8.9310.0 built by: NET481REL1LAST_C
帳務小管家 E-Money
    組件版本: 20.25.0.5
    Win32 版本: 20.25.0.5
    程式碼庫: file:///D:/%E5%80%8B%E4%BA%BA%E8%B3%87%E6%96%99/%E5%B8%B3%E6%9C%AC/%E5%B8%B3%E5%8B%99%E5%B0%8F%E7%AE%A1%E5%AE%B6Emy.exe
    組件版本: 10.0.0.0
    Win32 版本: 14.8.9032.0 built by: NET481REL1
    組件版本: 4.0.0.0
    Win32 版本: 4.8.9256.0 built by: NET481REL1LAST_B
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    Win32 版本: 4.8.9032.0 built by: NET481REL1
    組件版本: 4.0.0.0
System.Core
    組件版本: 4.0.0.0
    Win32 版本: 4.8.9316.0 built by: NET481REL1LAST_C
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    Win32 版本: 4.8.9214.0 built by: NET481REL1LAST_B
    組件版本: 4.0.0.0
    組件版本: 10.0.0.0
System.Data.resources
    組件版本: 4.0.0.0
    程式碼庫: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.resources/v4.0_4.0.0.0_zh-Hant_b77a5c561934e089/System.Data.resources.dll
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
當 JIT 偵錯功能啟用後,會將所有未處理的例外狀況
傳送給電腦上已註冊的 JIT 偵錯工具進行處
richer
文章: 42
註冊時間: 2012年 2月 15日, 23:29
Re: 複製帳務後立刻執行編輯有時會出現錯誤
文章o慕雲o » 2025年 10月 8日, 11:02
richer 寫:複製帳務 ( 按鍵盤 F8 ) 後,立刻執行編輯帳務 ( 按鍵盤 F3 ) 有時候會出現錯誤訊息。
錯誤訊息的內容如下
詳細資訊的內容如下
    組件版本: 4.0.0.0
帳務小管家 E-Money
    組件版本: 20.25.0.5
    Win32 版本: 20.25.0.5
    組件版本: 10.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
System.Core
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 10.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
    組件版本: 4.0.0.0
系統會不穩定或出現錯誤的問題為 Windows 11 更新所造成(會出現此問題時者都是最近有執行 Windows 更新動作)
關於此次的 Windows 11 更新災情說明可參考以下連結說明
https://asoft-store.com/post/68c602fc3eea5
而最後的總結為請將 KB5063878 KB5065426 這二個有問題的更新移除後系統即可正常使用
我們建議直接將 Windows 8 及 9 月份的更新都移除(Windows 11 24H2 都不要更新)
註:該問題是針對某幾家廠牌的 SSD 與硬碟使用量超過 60% 的使用者
以下影片有說明受影響的的 SSD 品牌以及要如何移除更新說明(移除更新教學在影片中後段)
https://www.youtube.com/watch?time_cont ... YzLDI4NjY2
文章: 19144
