電腦無法與手機資料同步
電腦無法與手機資料同步
文章applemei » 2012年 6月 25日, 23:55
您好,因為希望把手機上的資料轉到PC的帳務小管家軟體,在同步前好像建議先download "ODBC"
可是在下載的過程中發生了無法下載的問題,我的pc是window 7 (64位元)請問是不是版本不相容的問題?
很苦惱耶..
applemei
註冊時間: 2012年 6月 20日, 21:55
Re: 電腦無法與手機資料同步
文章o慕雲o » 2012年 6月 26日, 07:28
applemei 寫:您好,因為希望把手機上的資料轉到PC的帳務小管家軟體,在同步前好像建議先download "ODBC"
很苦惱耶..
不會喔
您應該是下載不完全
或者是防毒軟體擋住了
請您再試著下載一次看看
或者是用其他部電腦下載看看
我這邊測試 Windows 7 64bit 下載沒問題喔
Re: 電腦無法與手機資料同步
文章applemei » 2012年 6月 27日, 22:27
謝謝你及時幫忙,手機資料已經可以跟電腦同步了^^
applemei
www.raybanshopstyles.com 94
文章Pedsadminna » 2012年 7月 2日, 13:36
Trend is ever-changing and developments in the different accessories go on varying from time to time. Nevertheless, there is certainly particular classic apparel that by no means adjustments including the little black dress for the get together or even the Wayfarer shades. Your ray ban glasses is one of the timeless classics and will by no means walk out manner. It can be one of the hottest merchandise for the trend arena as well as typically embodies the actual good ole' 'n' spin style fashion.
The actual Beam Exclude Wayfarers 2140 are well-liked by celebrities as well, and also virtually all movie actors along with performers and also other crucial men and women of various industries result putting on the particular 2140. In addition, the particular Jimmy Ban 2140 sizes and colors on accessible and therefore it is possible to decide on in accordance with your personality and choose the one which fits you the top.
In addition, the actual Beam Ban 2140 polarized will make sure that your sight remain safe perhaps the best sun rays which is particularly suited to people that devote lots of their time outdoors. You may browse the World wide web to the distinct provides and special discounts on the Beam Prohibit 2140 price which is definitely affordable for you personally.
Your shades happens to be a should have for those who have the fetish pertaining to sun shades. The explanation for that is until this vintage eternal layout won't get out of style and this will often cause you to be look incredibly superior and trendy.
You may get adequate information regarding these kind of sun shades online in addition to there are a variety of internet sites giving information regarding the same; all you need to perform is actually hunt for Ray-Ban Unique Wayfarer 2140 sun shades about just about any key search engine or you might refer virtually any trend journal as well. This sunglasses have been in existence for years and is undoubtedly a favourite.
Pedsadminna
