拍賣小管家使用問題詢問
拍賣小管家使用問題詢問
文章p0927357194 » 2012年 2月 12日, 00:02
哈囉~你好
我2/11日有跟你購買拍賣小管家註冊碼.以成功註冊.不過我發現為什麼我註冊後他還是測試帳本.我為什麼要進入哪個畫面她多會顯式測式帳本的小視窗然後還不可以存資料.不知我哪個地方用錯出問題.像我要進入帳本選擇他還是會先出現一個全多是英文的小視窗他還有個圈打叉叉然或我按Details他會出現以下
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: ExecuteReader requires an open and available Connection. The connection's current state is closed.
at System.Data.OleDb.OleDbConnection.CheckStateOpen(String method)
at System.Data.OleDb.OleDbCommand.ValidateConnection(String method)
at System.Data.OleDb.OleDbCommand.ValidateConnectionAndTransaction(String method)
at System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(CommandBehavior behavior, String method)
at System.Data.OleDb.OleDbCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.OleDb.OleDbCommand.ExecuteReader()
at WindowsApplication1.帳本管理_帳本資料設定.LoadNoteList(Double 帳本編號查詢)
at WindowsApplication1.帳本管理_帳本資料設定.基本資料_帳本資料設定_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.RunDialog(Form form)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at System.Windows.Forms.Form.ShowDialog()
at WindowsApplication1.主畫面_拍賣小管家.工具列_ButtonClick(Object sender, ToolBarButtonClickEventArgs e)
at System.Windows.Forms.ToolBar.OnButtonClick(ToolBarButtonClickEventArgs e)
at System.Windows.Forms.ToolBar.WmReflectCommand(Message& m)
at System.Windows.Forms.ToolBar.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3623 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
拍賣小管家
Assembly Version: 3.3.0.0
Win32 Version: 3.3.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/桌面/拍賣小管家.exe
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Win32 Version: 2.0.50727.3624 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic.Compatibility/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.Compatibility.dll
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Assembly Version: 10.0.4504.0
Win32 Version: 10.0.4504
CodeBase: file:///C:/WINDOWS/assembly/GAC/dao/10.0.4504.0__31bf3856ad364e35/dao.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
請問一下是哪個地方錯誤.感謝幫忙
p0927357194
註冊時間: 2012年 2月 11日, 23:51
Re: 拍賣小管家使用問題詢問
文章o慕雲o » 2012年 2月 12日, 10:14
p0927357194 寫:哈囉~你好
請問一下是哪個地方錯誤.感謝幫忙
請問您是在執行什麼動作時會有錯誤訊息呢?
另外可否請問您現在所下載的 拍賣小管家 的版本是幾版(目前最新為 3.3 版,我們在露天放的版次沒那麼高)
可否請您試著下載 拍賣小管家 3.3 版後再執行試試
viewtopic.php?f=4&t=7
文章: 18525
